M
maskedman72
Member
allright, there are many interesting points to consider here.
i have a totally untreated square room that is about 11x12 1/2 and i am not in any way unhappy with the way my recordings sound, but i know with some treatment my sounds can get better.
is there anything you shouldnt treat your room with? if i use that spray can adhesive will it ruin my wall(drywall) if i wish to remove it? i see that guitar center now carries the spray can adhesive and sheets of the wall foam. are you supposed to cover your walls from floor to ceiling with it? i think talking about how to get started in treating your room(in english)would be a good thing.
how can you hang the foam without trashing your walls? how much foam do you need on a wall? should you cover the wall or space out the sheets and expose some of the wall?
No seriously I think there are way better traps out there. If you want to absorb down below 125hz you need Ethans Real Traps.
