kid klash
The original Mr. Nice Guy
GREAT review. Thanks Harvey.
Depends on what the vocalist needs. I think the 190 might be a better vocal mic (as far as being a lot more neutral), but sometimes a singer needs an aggressive mic. It's too soon to really get a handle on either mic; you hafta live with them for a while.TheHunter said:@Harvey as always... Thanks for the review. Can you post some sample clips I think that would be helpful.
Which of these mics do you think good for vocals?
Yup it's threaded to take matching threads on the mic; same thing with the Cube. They both screw into the shock mount.junplugged said:190 shock mount looks like it's threaded?
Any word on the proximity and overload issues?Harvey Gerst said:...
Back to the T3 and switching with the MXL 190. The 190 has a smoother warmer sound without much of any peaks that I could hear. But either the proximity roll-off switch was stuck in the on position, or this mic doesn't have a lot of proximity effect. I'll check the switch tomorrow. Overall it's a pretty nice mic, but it does overload pretty easy up close. I didn't try the -10dB pad to see if that would fix it.
It's a little smoother than the T3; it doesn't have that high end sheen like the T3 has. But it's not a "dark" mic either. Alex said it reminded him of the "N" word. It definitely has a M149 kinda vibe to it. The new shock mount is amazingly well crafted and works for the Cube as well.
More testing to come. These are just first impressions.
Testing mics is really a two person job and Alex won't be back till Monday. I'll see if we can sneak it in before a session. We also have a big load of Avant mics that are coming in as well.crazydoc said:Any word on the proximity and overload issues?
MXL Bullshit on website said:* Gold-sputtered, 6 micron diaphragm
* Internally wired with Mogami cable
* FET balanced output
* Unique small size/low-profile
* Comes with mic clip (optional shockmount available)
With MXL's Cube, home and project recording studio engineers have a versatile microphone that is well within their budget. The Cube is a cardioid condenser mic that delivers powerful, clear, and detailed vocals and shimmers with acoustic instruments and percussion. Its frequency response ranges from 20 Hz - 20 kHz, making it ideal for a wide range of recording tasks.
Featuring a 1-inch gold sputtered, six micron pressure gradient capsule and a low-noise FET (field-effect transistor) preamp with balanced transformer coupled output, the Cube delivers big sound from its surprisingly diminutive size. Further contributing to its pristine audio quality is the fact that the microphone is internally wired with Mogami cable?the choice of recording professionals everywhere. The MXL Cube has a beautiful champagne finish and ships in a protective case. The best part about the Cube is that it looks as good as it sounds.
crazydoc said:Just a heads up on the Cube:
There is no case (foam in a cardboard box) and the transformer seems to be invisible. I tried to post pics but the site is not letting them upload.
Obviously they sent you mine by mistake. Please ship them to me ASAP.MCI2424 said:I just got mine and it came with 2 cases and 2 transformers.
Wowie!!!!
