the glory and the dream (kinda heavy)
  • Thread starter Thread starter giraffe
giraffe said:
double pedal
same thing (about the low end) kaints said, and yes something is going on down thare i need to tame. probably the bass (maby one of the gits), never quite been happy with the sound.
i'll play with it more.
i previously tried some cuts in the low mids (over the master), but i like the power comeing from that area.
maby i need to reconsider.
bass could prob just come up a little too.
(usually a bass in one of my mixes is to loud, this is a change)
thanks to all
The bass itself may already be plenty loud enough. It's just not distinct enough. Try soloing the track and get it more distinct and then listen to it in the mix. When solo'd the bass should sound almost TOO thin. But when placed back in the mix it will fit. Try it. You'll see. Then when you get it sounding clean and crisp you can determine whether you need to bring it up in the mix or not. Now, I'm assuming that it's possible you may not know this so if you already do, no offense intended. ;)
