c7sus
Disenfranchised Member
Not following you....
How are you loading the Roots expansion pack if you didn't get the initial EZD/Avatar stuff to load....?
IOW....you would need the basic app loaded before you start adding expansion packs.
SD2 loaded right up. Then I tried to load the Avatar library and it failed. It loaded partially. I can see the file but the files won't play. SD couldn't find them at all and had to be pointed at them. When I try to use the uninstaller I get an error message that there are no files in the file. Instead of a file that says "SL-Avatar" my files are simply "soundsb1", "soundsb2", etc.
So I decided to try loading the Roots pack and while it took about 2 hours to load all 5 disks it worked and the samples are really great. After it loaded SD found the path to the Roots files and all the kits play.
I had read about folks having problems with the upgrade. Gonna call Sweetwater next week and see if they can send out another set of disks with the Avatar files or how they have been addressing this problem.
