sweetbeats
Reel deep thoughts...
Oh I get it...okay. No pic needed. The little sockets that go in that connector housing slide in and click into place. It's possible they can dislodge and get pushed back. The wire that goes into position 5...can you pull it or push it to see if the metal socket is just sliding around in there?
If so see if you can pull it all the way out of the connector housing. If you can you'll see a little metal prong/tab on it that's supposed to protrude so when you push the socket into the connector housing it clicks into place. If that little prong/tab is smushed down it won't lock the socket into place. You can take a pocketknife blade or similar and pry the prong/tab out a little so it locks again.
If I'm totally off-base and the socket is missing or too damaged to be any good ignore the above and swap the assembly out. If we were close to each other I could replace that socket.
