K
kmaster
I just got a used TASCAM 246. I knew it needed a bit of work, but I was ok with that as I've had some small electronics experience and the whole thing was really cheap ($50 for the unit and a few boxes of ok blank tapes), so I figured at the worst it would be a learning experience. I've cleaned out the old "melted" rubber bits and ordered replacement rubber parts, which should be here in a few days.
Right now, though, when I power on the unit, I hear a motor running, but nothing's moving... is that normal, if nothing (like "Play") is selected? Is this indicative of a bad motor? Granted, I don't have any belts in, but literally nothing is moving, so that shouldn't matter.
I'm sure it's the motor that powers the idler tires (like the similar 244's tires in Dr. Zee's pictures here). I guess my question is: what is the normal operation for this motor... i.e. is it supposed to do that?
And, if not, where can I get a replacement motor from?
Thanks!
Thanks!
and just wait untill you get the belts
