evm1024
Vacuum and tapes
I use a vacuum pump to treat film for astrophotography. I bake the film in a converted preassure cooker sitting in an electric skillet of water. the cacuum helps get the water and oxygen out of the film backing.
This cooker would fit a 7" reel (actually 10 reels) with precise temp regulation. I don't thank that you need to pull a very deep vacuum so most any small surplus pump would work.
I'll have to give this a try. I have some sticky reels of Ampex 791 data tape. I think that a day or 2 in vaccuum and then bring the temp up to 130 for 4 hours.
The room temp vaccuum is to pull the water out of the tape and the heat is to "recondition" the oxide and backing binders. I'll have to see if heat and vaccuum will boil of any of the needed adheasives and lub.
All speculation of course. Regards, Ethan
