N
notbradsohner
Compression Addict
can somone please clear this up. <"Got it...
I figured out that I can run signal into both the front and rear inputs on the headphone amp, so all I need to do is run out of the direct out on the board, without signal mixed into the mixers output.
Radio shack had a little red square momentary switch that is exactly what I was looking for for $2.99, with 2 prongs... gonna mount that on the front trim of the desk, facing me but to the right under the mouse. Snip some sheathing off a cheap mic cable, expose the wires, cut the black wire and run it into the switch, and instant talkback button, no monitor problems. Mount the cable under the desk too so as to not be seen or bother me.
I like it.>"
so, when i open up an old mic cable, ther is a red and a blue wire. Do i wire one color to one prong, and vice versa? Is it kinda like a through swithch, that will only allow the signal to pass when the button is pressed? here is the like to the button.
http://www.radioshack.com/category.asp?catalog_name=CTLG&category_name=CTLG_011_002_015_002&Page=1
thanks
I like it.>"
thanks
