Studio Monitor Mixing Questions!
Iwannamix
Does the placement of studio monitors effect the mix ? (RAP VOCALS)
Does The Loudness of the Monitors ?
I use Logic Pro 9
EQ's Looks Like this:
Compressors:
(On Chain)
(On Chain)
Compressor
On BUS
Reverb BUS
Delay BUS
Here's what my home studio looks like tell me anything i could change aside from obvious foaming.
My Home Studio - YouTube
I get this result when i mix my homies traacks - https://www.youtube.com/watch?v=Am9Gi2qXuWI
mjbphotos
What?!?
Yes and Yes. If you know what a GOOD mix sounds like with your monitors, then you can work with them knowing your 'studio'. The best method is to mix, burn a copy, then listen to is on as many different systems as you can. Then go back, 'fix' (remix) and do teh same again.
Your youtube video is private - can't view it. Read the Studio section of this forum before buying a lot useless foam.
Massive Master
www.massivemastering.com
Everything about the monitoring chain effects everything. Every decision you make (including what looks like some pretty interesting EQ choices) is based on how the monitoring chain translates to your ears.
I can't even imagine working through a non-calibrated (for loudness) chain.
