Aren said:
Frederic -
I took a look at your gear list, and noticed that you use Aiwa monitors, with some midification. I'm using Aiwa speakers as monitors, and found out that after learning them for a long time, I can get a pretty good approximation of how my mixes will sound anywhere else. (They still sound like crap, though...
Can you please explain about your modifications?
(Use a personal message or E-mail if you want...)
Oren
Hey Oren,
Sorry this took me soooooo long to get back to you. Been hell with work and remodeling my kitchen (which was a suprise item on my weekly "honeydo" list. Anyway, yes, I do use Aiwa home theater speakers, with some modifications. The units I have are AVSX1000's, which have dual 5.25" aiwa woofers and a 1" tweeter. I lay them on the sides, tweeter's out, but in reality they could be standing up if you prefer.
Now, for the modifications.
I yanked out the two woofers and replaced them with a pair of Audax AP170ZO 6.5" HD-A cone woofers and the tweeter was replaceed with a TM025F1, both available from audix. The woofers obviously did not fit into the holes, so I used my router to make room
Because the volume of the aiwa cabinets was not quite ideal as compared to the design I sorta tried to emulate
http://www.audax.com/doit/us_ht06.shtml) I had to make minor port changes as well as tune the crossover. THe crossover was a cheapo 2-way crossover that had the crossover point too high (5K) for some strange reason. Its been modified to bring the crossover point much lower so that the woofers are in their operating range and more efficient.
Because even with 6+" woofers, the bass is lame, I have a subwoofer in series with the two monitors that provides additional bass. I have this wired up with a bypass dp8t toggle switch that allows me to put the stereo sub in and out of the circuit so I can monitor both ways. I find listenening with and without the sub to be an excellent way of not adding too much bass, or not having enough. I guess "idea" would be the sub produces 1/2 the volume?
Anyway, I hope that helps. I'm also going to send this to your email directly
