Storing bass traps
  • Thread starter Thread starter frank1985
F
frank1985
Active member
Greetings folks, I just wanted a second opinion on this...
I've decided my current studio setup is inadequate, and want to store my gik bass traps away until I have access to a larger, more suitable recording/mixing space.
I'm converting the current studio into a bedroom. My only real options other than leaving the bass traps hanging on the walls is to store them away in the attic or the outdoor cabin, both of which are unheated. They take up a lot of space so I've no other options unfortunately. It's hard to say how long they could be stored away for, possibly years.
I've been advised that high humidity and cold temperatures (UK climate) can possibly degrade the rockwool over time. Are there any precautions I can take to temper this, such as wrapping them in a particular type of material, like bin liners for example, or will that not make a difference?
Grateful for any advice as I obviously want to avoid damaging them.
Dehumidify your room.
Rockwool is sold for insulation purposes, so I doubt it will degrade from being stored in an attic. Even the Safe n Sound grade is sold for interior wall insulation use. Heat and cold won't bother it.
Safe n Sound grade is listed as being water and moisture repellent. Stone wool does not rot or promote the growth of mildew, fungi or mold. As long as it's not allowed to actually get wet, it should be fine.
Concur with the others - the Rockwool site has a pretty useful FAQ - if wet, when dry it recovers it's properties, it does not absorb water, actually repels it and temperature range is extreme - negative temperature are very capable
info here
