regarding SSS, restoration experts within the ARSC (Association for Recorded Sound Collections) have found that what was thought to be oxide binder break down is in reality back coat binder break down with the contamination transferring to the oxide of the next layer.
The back coating was cleaned or removed and the tapes played fine.
If you are trying to retrieve a tape with SSS and dont want to do the baking routine, try cleaning the back coating. Be careful not to use solvent that will also dissolve the oxide binder.. Do Not tholulene or Mek are basic solvents used in mixing the oxide binders.
There is ongoing study on this finding........... I'll keep you informed
d nelson ward
