dachay2tnr
One Hit Wonder
One final suggestion from me.
In Options > Audio > Advanced there is a setting for I/O buffer size. Have you played with that setting? Try it using different multiples, i.e., 16, 32, 64, 128, 256, 512, etc.
If that doesn't help, try changing the buffer latency in the Delta control panel and then doing the above again.
In other words, see if you can find a combination of latency in the Delta Control Panel and the Sonar I/O Buffer that eliminates the problem. I have a machine that will only run properly when the Sonar buffer is set at 64. Any other setting and I get dropouts.
Worth a try if you haven't already been down this road.
Especially if you are running XP OS.
