famous beagle said:
Yep. Modes are the most misunderstood things in the guitar world. People make such a huge deal out of them when ... like you said ... IT'S JUST A MAJOR SCALE. The only time they come in useful is when you superimpose them on different chords. For instance, if you have a one-chord Dm7 vamp, you could use several different "minor" modes (Dorian, Phrygian, or Aeolian) to get different results. You need to know them, so you don't have to keep referencing back to major scales in different keys for things like that.
That is just the simplest use you can give to modes. You can actually play ANY, and let me say that again, basically ANY IMAGINABLE scale over a simple one-chord vamp as you are saying, and it's gonna sound fine. A little odd or "original" perhaps depending on which you play, but good in general. And the reason being that a single chord does not define any harmonic key/progression, e.g. Dm7 is part of C major, Bb major and F major and their relative minor keys. Not to mention other harmonic modes and variations...
Any given mode, including the two most known and used "major" (Ionian) and "minor" (Aeolian), defines a certain harmonic structure. Just write the notes of that mode on the staff and construct the triads on top.
And as some of you still not so much into the "world of modes" might get confused about it, let me clarify something here. Each mode is built upon a "scalar" formula. The traditional "major" (Ionian) mode follows:
1-1-1/2-1-1-1-1/2
so C Ionian (or major) is: C-D-E-F-G-A-B-C
whereas the Mixolydian mode follows:
1-1-1/2-1-1-1/2-1
so C Mixolydian would be: C-D-E-F-G-A-Bb-C
So once you learn the basic scalar shapes on the guitar you can just play that shape beginning on a given note, and the mode you are playing is called "that root note" + mode name. So going back to these two cases, and as I aforementioned, the first one is said to define C major harmony, whereas for the second, the underlined harmony IS NOT C, but F major.
Now, trying to wrap it all up, if you had a chord progression in C major, say:
CMaj7 | Emin7 | Amin7 | Dmin7 | G7 | CMaj7
you could solo by using the C Ionian mode safely with no worries, all over the progression. But an interesting alternative is also to break your solo up into three sections:
- Over the first two chords, CMaj7 | Emin7, you could just play C Ionian.
- Then, over the next two chords, Amin7 | Dmin7, you could now play C Mixolydian... Weeehhhaaa!!!!
- And then, over the last two, G7 | CMaj7, you ought to come back to playing C Ionian (not really... but let's stay focused for now).
Try it at home, no safety concerns involved, just a word of advice: Make sure you do not over-emphasize the "odd" notes (in this case just one, Bb) when you play over this simple progression, as otherwise it'll sound a little too odd.
But you'll certainly be giving your solos a different twist and flavor, as I said. This is just another application of modal playing and harmony.
famous beagle said:
But when people say to approach a ii V I progression with "Dorian, Mixolydian, Ionian," that's just a waste of time. If you're in the same key the whole time, you don't need to worry about modes.
Beagle: I'm afraid this is incorrect. I think your comment is coming from seeing the modes as scale positions over the fretboard, where as long as you play one after the other on the same key, there is no need to worry about the mode's name.
But this is not correct as I hope I made clear above. You are
NOT playing C Ionian, C Dorian, C Phrygian, etc all over the place, but rather C Ionian, D Dorian, E Phrygian, F Lydian, G Mixolydian, etc. Is this clear? One of the "magic" with modes is be able to play "modally" over the same tonal center (key). Another is using a particular chord progression underlined by one given key and mode. Guitar players like Satriani, Vai, Alex Skolnick (ex-Testament) use a lot this approach and are eager modal players. Listen to some of their music and you'll probably notice those different-sounding themes that you probably cann't explain how they came up with, and are all based on modes.
Have fun.
