P
Pianoguy
I make videos of somebody playing the piano. I have a good-enough solution for the audio, using two mics and a Focusrite USB audio interface. For video, I use a webcam.
The way I produce these videos right now is, however, overly complicated. There must be a better way, and I'd be glad for any suggestions.
Currently I'm recording the audio using Garageband while at the same time using Quicktime to record the video. I export the audio to a file in Garageband, save the Quicktime video to a file, and import both in iMovie, where I manually synchronize the audio track and the video track and do the actual video editing.
All this import/export and manual sync is rather tiresome. There must be many other people who have similar requirements, since I assume my use case is rather common. Hence I'm hoping that there is some more integrated software solution. Ideally I could record audio and video in the same application and do both audio and video editing there, without switching between different applications and file import/export and without manual synchronization of audio to video.
Any suggestions?
Any suggestions?
