Sorry for the long absence here. I have been very busy. We are the designers for SAE school here in Jakarta and for the Digital Media Center at Foothill college in San Jose, CA.. not to mention the many studio builds all over, large and small.
Any wall in a critical listening room counts. You will always want to control the propagation of sound from the source (speakers) so that there is zero interference at the listening position. Reflections from the operator/listening are treated completely differently.
My RT-60 criteria is determined from:
http://tech.ebu.ch/docs/techreview/trev_274-hoeg.pdf
Subjective assessment of audio quality
http://www.itu.int/dms_pubrec/itu-r/rec/bs/R-REC-BS.1116-1-199710-I!!PDF-E.pdf
METHODS FOR THE SUBJECTIVE ASSESSMENT OF SMALL IMPAIRMENTS IN AUDIO SYSTEMS INCLUDING MULTICHANNEL SOUND SYSTEMS
http://www.aes.org/technical/documents/AESTD1001.pdf
Multichannel surround sound systems and operations
http://tech.ebu.ch/docs/tech/tech3276.pdf
Listening conditions for the assessment of sound programme material: monophonic and two–channel stereophonic
This boils down to the following formula: RT60 = 0.25*((room volume in cubic meters/100)^(1/3))
This should be a straight, horizontal line. From 200 Hz down to 63 Hz, the decay (RT60) may rise by 25% maximum.
It is used in BOTH (imperial & metric) of my room mode calculators available for free download from my publications page. This information is seen in cells L57 and N57 of the first tab on the imperial version - L60 and N60 of the metric version.
40 Hz is 28 feet long. It could be that you have a heavy partition at 28 or 56 ft.. or even 14 ft, and it could cause the issue. There could also be other resonance issues. That's why testing is always the 'fail-safe'. As much as I would like to say that everything can be calculated, most often it is the factor that is omitted or forgotten that really messes up the equation.
- you know what I mean...
So it's back to the detective work; as Sherlock Holmes would always say, 'Eliminate the suspects one by one, and then whatever/whoever is left (no matter how unlikely) must be the culprit.'
Jim, Can you run some sweeps with REW and post the MDAT file? One speaker only. I'd like to see what's going on there. And please list the exact construction of your walls.
Cheers,
John
