BroKen_H
Re-member
It corrects specific frequencies. Or course, by your chart, it wouldn't do you a whole lot of good as they nominally only work from 1500Hz up. You look pretty flat there...sorry, wrong direction.
IDK, if I can get my room to look that flat from 50-12k, I'll be very happy.
Okay, got most of my trapping up, and I've got a couple of frequencies I'd like to tame. I've got two nulls: 514Hz dip ~8dB, 950Hz dip of ~6dB, and a 5dB spike at 1613Hz @ 60dB Pink Noise. Any advice on the best way to render these flatter? My room is quiet and sounds very good. I measured at the sweet spot. Should I build a diffuser for the nulls on the back wall? Should I just use a parametric eq to deal with those three frequencies at output (like Equalizer APO)? Should I just get used to how it sounds and deal with it?
Thanks!
REW is the software used to test your room.
stuff like Owens Corning 703 insulation work well enough or is it worth it to invest in acoustic foam?
