B
Bigus Dickus
I have an M-audio Delta DiO 2496, and I'm using a coaxial S/PDIF input from an external A/D converter. Since my soundcard doesn't output wordclock, then I have to either sync the soundcard to the A/D converter, or let each use their own internal clock.
I'm thinking syncing the soundcard to the input coming from the A/D converter might help reduce jitter, in that even if the soundcard has a better clock (I doubt it), at least the two would be in sync. Unless using PLL's to sync to a coaxial S/PDIF input isn't a very good way to use an external clock (since the soundcard has no wordclock input either), and results would be better using the two independent clocks.
I'm using 24 bit 88.1kHz sampling, and the A/D converter is part of the dbx 386.
), and I'm hesistant to make assumptions.
