Shielding - Yay or Nay?
  • Thread starter Thread starter TelePaul
Gwt your coils shielded?
  • Yeah
    Votes: 13 81.3%
  • No way
    Votes: 3 18.8%
  • Total voters
    16
Nah
Doesn't seem worth it.
Its part of the guitar to me now.
Adam
naah. i tend to find some of that noise to be a character of single coils, and it needs to stay that way.
If it is a problem for you, the absolutely, but if it is not a problem, don't bother.
Light
"Cowards can never be moral."
M.K. Gandhi
I did it following the instructions precisely, but it didn't make enough of a difference to justify the work.
This seems to fall in the "old dog" category.
I'm usually game for reducing noise any way I can.
You didn't do it right. Period.
Not necessarily. It depends on a lot of things, but the coils themselves are more susceptible to picking up hum than is the internal wiring, and you cannot shield the entire coil. Shielding the cavity can help, but it won't make single coils noiseless.
I beg to differ. I'm not retarded. I'm pretty handy with a soldering gun and generally understand things mechanical/electronic. I followed every procedure precisely, and while it did help some, it didn't help enough to warrant the effort. The guy that wrote the instructions even said that it doesn't always work. I guess I'm one of those cases.
oh yeah, , you should alway's shield, especially if you have a CRT monitor for recording, becouse yes I can see some people liking the noise, but with alot of cheeper guitars you can get shocks from the strings, and the noise can sometimes rule out the actual music, the only guitar I have that isn't shielded is my strat clone, but only becouse it's coverd in ductape that I don't wanna remove
That has nothing to do with the guitar, and shielding won't help a bit. That's an issue with the amp, and needs to be taken care of.
Light
M.K. Gandhi
shielding does ground. tho I admit Light is probably right in it being the amp.
It didn't work for me either. I'd like to think that I'm pretty good at following directions and shielding isn't a complicated thing to do.
Shielding is GROUNDED, but it has no effect on the guitars ground. You can not, for instance, use the guitars shield as a ground buss, or at least not very successfully.
But yes, shocks are a problem with the amp, or with the power, or with the PA (if the shock is coming through your lips when you touch the mic). Some idiot electrician wires a recepticle backwards, and it can ruin your whole day.
Light
M.K. Gandhi
shieling like you said is grounded, and since static electricaty is alway's trying to find the easyest way to ground, it will more likly take the highly conductive shield than your body, unless ofcourse your body is closer... which is probably likly... I'll shut up now... listen to light, he's smarter than me.
In theory, a shield should work as a ground buss, and it sometimes does. What I'm saying is that I frequently have problems with it, and have never had problems with a groung loop in a guitar from soldering proper ground wires. In other words, it is a bad idea to rely on the shield for your ground.
Light
M.K. Gandhi
