RICK FITZPATRICK
No, its me thats sorry. You misinterpreted my intent. I didn't mean to imply that you tried to fool anyone. I meant...your PLAN SECTION was INCORRECT, which is the whole point of drawings. If they are incorrect then people interpret them wrong. Anyway, no harm done.Sorry.....I'm really not trying to "fool" anybody. Just bad drawings I guess.
All of them. And frankly, if ISOLATION is your prime criteria(and I think it is or why would you go to this trouble to only half-isolate which might as well be zero) it would behoove you to consider the windows as "decoration" on the exterior, and frame in window fillers. We'll show you how if thats your decision. Otherwise, two leafs of HEAVY glass with a transmission loss equal to or greater than your final wall design is in order.Are you saying do RC on the west and east walls or all the walls?
That depends on the db profile you intend to generate up there. In otherwords, do you KNOW how loud it will be? I doubt it. Thats why you need to overkill to guarantee the transmission loss will be greater than the db profile. However, lets put it this way. If you are generating HEAVY METAL rock, at 110db, I would say you will fail. Even 4 or 5 layers could possibly fail at that volume, if all flanking paths aren't taken seriously. But see my disclaimerI know the RC is for decoupling, but would adding the extra mass to the roof sheathing give enough STC to make RC unnecessary?
I believe so. Sound propagates in a hemispherical wavefront. You can hear jets 1000 ft above, correct? I beleive that sound escaping from a second floor is WORSE, as it can spread farther, having very few objects to diffract around as sound generated at ground level. But see my disclaimer.I was thinking that any sound escaping from the roof would be hard to hear on the ground since it would be so high up, so I wasn't that concerned about it.o I wasn't that concerned about it. I am more concerned with the south wall and the floor. Am I thinking wrong?
However, imagin your house is on the highest hill overlooking a valley. Sound would travel MUCH farther, although for every doubling of distance it looses 6db. Believe me. I live on said hill.
Here is one type of underlayment.What exactly are you talking about on the "ROLLOUT fiberglass/puck" flooring?
http://www.kineticsnoise.com/arch/lpsoundmatt.html
Here is the type I described.
http://www.kineticsnoise.com/arch/rimwood.html
And yes, it would create a VENTED third leaf, although this would DECOUPLE and act the same as RC on the wall, thereby creating a quasi "room within a room". I believe the room below is a garage, so who cares. It acts as a sound lock, no? But my disclaimer says it all.
Well, its time for work and I'm outta time. I'll be back.
DISCLAIMER....These are only opinions from a NON EXPERT.
fitZ
Another area of concern is electrical. Penetrations in the innerleaf envelope for lighting and outlet boxes can become potential flanking paths and or leakage into what should be a HERMETICALLY sealed airgap. Another concern when it comes to firestops is coupling the two leafs together, thereby creating another flanking path. Anyway, here is the jamb detail(for example purposes only)
Even though the extra mass may have helped, it totally negated the advantage of using RC not to mention creating a three leaf system. Hence my suggestion of RESEARCHING each and every detail of the solutions you choose. Ok, thats all I have time for at the moment. Remember my disclaimer though.
)qualities. Something like that .
Anyway, its because of this quality that vibration is dampened differently than with Liquid nails or other brands of adhesives.
