Slouching Raymond
As I can't find a Scribble Strip thread, I'll start one.
Just want to share this bit of turmoil.
I've been researching what to use on my SSL XL-Desk console.
I will need a scribble strip, because I won't be able to remember what's where.
I have 16 mono channels, 4 stereo channels, and if I press the 'alt' buttons in mixdown, I can double up on the mono channel count
by shoving daw signals into both the A and B inputs, and using the stereo cue bus as a summing mixer as well as the faders.
There is board space allocated for a scribble strip, so I will have to stack two rows of names onto it.
What I looked for is non-permenant tape.
It goes by several names:
Pro Tape
Console Tape
Board Tape
Artist Tape
It appears you can buy Pro Tape in America easily, but not in England.
I had a roll of Post-It one inch slightly sticky paper, which I used before, but you can't even buy that.
So I bought some Low-Tack masking tape, which is removable, but the instructions said
'Remove it by three days, or else!'.
Things were not looking promising.
I hatched a plan to make a removable solid scribble strip bar, which could be just placed on the console, or placed on any table to write on.
This would save me from nudging faders or knobs while writing.
But how do you keep it in place? Peelable glue dots? Or maybe some kind of minimal support to keep it in position?
At this point I tried a little sheet music power magnet on the console, and discovered the console surface is steel.
That is now my plan - One little magnet placed discretely at each end of the row of faders, and then sit my removable rigid scribble strip
against the magnets.
I have 2 choices now:
A - Make the scribble strip out of aluminium.
B - Take a Whiteboard, and cut it into strips, and use non-permanent markers.
Plan B sounds promising.
Pro Tape
Console Tape
Board Tape
Artist Tape
