B
		BookSix
Hey guys, I am getting to my room treatments, but am not sure exactly what to do.  I am very inexperienced with all the room modes and calculators, etc..., but can you check out my pics and diagram and tell me if my idea's sound good?  Thanks
http://www.geocities.com/booksixstudios/Diagram2.jpg
http://www.geocities.com/booksixstudios/rearright.jpg
That's the diagram and photo of my control room. I was planning on putting a large 1/4' plywood curved difusor on the back wall between the two doors. Would this be effective? Should it be sealed with fiberglass insul behind it? Also, should the front angle down some?
Next I was going to use 2" rigid fiberglass (once I find a supplier) on the walls and ceiling, but I'm not sure what to make. I was thinking of replacing some of my ceiling tiles with rigid fiberglass. They all have varying space above them ranging from about 3" to probably up to 18". As you can see from the diagram, I have little space for a corner bass trap at the back of my room. Is there something else I can do in place of corner traps? As for the front, I was thinking 2" rigid fiberglass spanning the corners behind my monitors as well as the side corners. Is simply mounting a sheet of fiberglass on 2x2s the best method?
Any other suggestions?
http://www.geocities.com/booksixstudios/VocBoothfromControlRoom.jpg
http://www.geocities.com/booksixstudios/VocBoothfromHallway.jpg
Those are my vocal booth. It is an understair closet currently covered in carpet padding. I have no clue here. So any suggestions would be great.
I'll be back later with a diagram of my drum room. I think I have big problems there. But here's a photo. It was just a start (with the auralex I got for cheap), but I think I'm gonna take it down and fix my parallel walls before I put it back up.
