Sonarcade
Member
thanks for the mixing advice! I'm kind of glad that you bring this point up without my asking if the volume's too low. I was thinking that I was crazy or something. This has actually been my biggest issue. I first attributed this low volume to crappy equipment lacking the proper headroom but then there's someone in here who recorded a song that sounds pretty hot and was recorded in his mic input on his laptop! So I'm having doubts about the problems coming from limitations of my equipment and I feel as if it's now placed squarely on my technique.
When working digitally, using Ableton Live or any other DAWish program, I immediately head for the compressor, add it to the master track and adjust the ratio so the meters are about at -0.3 dB. I don't know if that's enough information, seeing as how I recall running into different units of dB, but I figure that there's some standardized unit that applies across DAW programs. Even then, however, the graphic EQ on winamp when playing back tracks seems to be on a lowish end, especially with higher frequencies. And of course, more imporantly than "seeing" it is the fact that it sounds pretty low. Although I'm some of this may be tied to a flattening of the dynamics from compression, I think there's something else more crucial afoot.
you can see why I looked to the analog realm to solve these problems as I was firmly convinced that it's all digital's fault and that analog allows for things to simply work out out-of-the-box. But then, I realize that somewhere in my recording path, it's inevitable that I'm going to have to hit those A/D converters if I want to distribute my music in an unwieldy and 21st century manner. So I'm back at square one.
*shakes fist*
*shakes fist*
