G
There is NO difference in sound sources....look it up.
Except stereo effects and amps (delays, reverbs, flanging, etc) that process the sound, hence delivering 2 different signals .... Typically into 2 amps or into a stereo guitar amp.
You know what's wrong with this argument?
You know what's wrong with this argument? It's debating the definition of something that doesn't exist.
Stereo amp setup, therefore, this becomes a stereo source. Assume each head in the pic has it's own cab. That's how you would run this stereo amp setup. The source sound is in stereo! The sound you will want to record will be in stereo. It will be a stereo sound, from a stereo source! Oh fuck, mind blown!
Some of you are hiding behind semantics just to make your moot points.
I think you know exactly what I'm saying and you're arguing just to argue.
<snip>
ster·e·o
ˈsterē-ō,ˈsti(ə)r-/
noun
noun: stereo
1.
sound that is directed through two or more speakers so that it seems to surround the listener and to come from more than one source; stereophonic sound.
And to further explain myself, that's the point we're trying to make. In order for it to be stereo, it has to come from more than one source (as we've called them, a "point source.") in order to be stereo. Things like a singer will never ever ever be stereo, unless you're relying on spatial cues such as reverb or the person running across the room while recording to do that.
There are instruments that can do this, they are stereo sources.
And there are instruments that can not. Those are mono or "point" sources.
If you want to be picky, yeah there are electronic instruments--keyboards or that guitar rig Greg described--that have stereo outputs but this is just the same thing as the definition above. They are using two speakers to SIMULATE the spread of sound across a room.
