Hmmm, there seems to be a bit of a misunderstanding of what I'm trying to do here, given some of the responses from other forums. I'm not trying to play like Ringo. I'm not trying to sound like Ringo's drums. I'm purely trying to recreate the recording process that Norman Smith used on those early Beatles records, to see how it would sound like with me playing, with my gear, on my drums (I deliberately wrote that text into the video because I just KNEW people would complain that it doesn't sound like Ringo, and it still happened!).
As far as the backing track goes, long story but this wasn't the one I intended to use, I had a collection of like a hundred backing tracks and I was going to use another one, but I lost the CD (problem when you hardly use optical media anymore is you misplace stuff) so I had to use one of the three backing tracks saved on my studio computer and went with this one, since it was my favorite of the 3.
I do plan on making a version 2 of this, since there were a few things I got wrong. The mono overhead is actually way too far away, I was going off of memory from what I saw in photos from the book "Recording The Beatles" (where I got all this information) but when I looked at it again after I shot and edited the video, the mono overhead was actually at Ringo's forehead height. We're about the same height, but he sits higher up, so it'll be a bit above my head, but regardless it should be viewable in the frame. That should help with the snare tone (the only thing I wasn't happy with). I also went too heavy on the compression, Norman didn't even use the Fairchilds on the drums, he used the Altec Compressor, which was much slower (fastest they could go was about 30 ms)....my compression choice would have been more appropriate for the later Emerick era. So I need to really slow down the attack and back off the drive on the plugin. Also, the bass drum ended up being a tad bit clicky, while I did like it, it should have been thuddier, so I need to play with that mic positioning some more.
If you see Get Back, they have a lot of information of how Ringo recorded/setup the last album. Pretty incredible that the album was recorded as a live band. But it shows how Ringo was set up. I was impressed of how tight those guys were in their final days.
Eventually I do want to go through the evolution of Ringo's recording setup. The next step is the Revolver setup, Emerick's first album as main engineer. In addition to the D19/D20 combo, he added a KM56 on the snare bottom. This one will have to wait, as I don't own any cardoid SDC and need to pick one up first or borrow one. After that would be the Sgt. Pepper's setup, where he close miked the toms and hi-hat with more D19's. Then I think I'll go with what Glyn Johns did on Let it Be, since it varied a bit from what Emerick did (I believe Johns used a U67 on the overhead).
