D
D.C.
BigRush said:9-duece gave you some really good advice! Although it was a bit "educated" (HAHAH!!)!!! I guess to repeat what he said in "dummy" speak, it try setting your Quantize to something like 50%. The one thing you may have to to do is go back and Make sure things that are supposed to happen on the down beat (The One), are actually there. If not, when you start the sequence there will be no kick, for example. The point is to make your tracks sound less mechanical and the mechanical sound starts with the hard quantize. Loosen that up a bit, then try to find sonds that compliment what you're looking to do (Thats a whole " 'nother " thread! )
The next thing I'd suggest is NEVER EVER EVER EVER EVER use the factory sounds unless you're layering them with custom stuff!!! Why? Two reasons: They are set to a "general type of sound, meaning they intended them to appeal to hip hop, house, trance, jungle, rock you name it. What drum sounds do you know of that are "general" to every style of music?? So find sounds that are suitable for YOUR music. Number 2: Its a matter of STYLE!! Hip-Hop in particular was founded on doing things with sound that no-one else did, even with all the factory churned out music today, guys who have a unique sound are the ones who get noticed AND COPIED THE MOST!!!! So if you started out using the MPC for instance, keep sampling drums from records and samples from vinyl. No sense in changing your flavor because you changed the way you operate. Thats like becoming an asshole when you get a porsche..(ok bad analogy, cause I AM an asshole now!! HAHAHA)... Don't use canned sounds!! It'll only make you sound like everyone else!!!
On the tech side, 92 was right, getting to know EQ and compression is extremely important. Most young cats see the drum machine and the subtractor and go nuts, but when it sounds like your speaker is covered with a blanket, or its so shrill you can't play it loud, you learn that eq and compression (when used wisely) can help a mix! We do differ on the fine points, but overall eq and compression is a big part of the total package.
I use ReWire sometimes. Like 92, I usually just export it all out and open Cubase or Nuendo (No diss to Pro-Tools!! Please no flames!). Sometimes I'll even export a midi file so I can double or replace sounds with modules like Trilogy or the NI modules!
FYI, I use the ReDrum (usually 2 of them do the trick), and now I am hooked on the Combinator!! I start with a patch I like and screw with it until i like it or hate it. If I hate it, I'll just startover...simple. Patience is a virtue not some old broad!! (corny!).
I will Combine strings with synths to get that perfect string for a particular record. The key is train yourself to keep throwing new stuff together so you don't get stuck using the same patches all the time.
By the way thanks for the love... Its cool when folks dig what you do! I'm looking forward to hearing some music from you as well....
Wish there was a place HERE to post music... I hate having to go update soundclick!!!
The reason I aimed that one at big rush is because I heard his music. It sounds good. I have heard alot of music done in reason were people say they are good with it but it sounds like some shit. Just what I think. Do not want to offend any one. I have searched all over for reason hip hop
music. It was just one other dude and he worked for Dr Dre on one of reasons sites.92 I feel what you are saying. I just love music point blank. What I get from the both of yall is that I have to find the sound from within the program. I feel the same way I just can not explain it. I just work with it untill it sounds right.More of an unconcious feeling.Also both of ya'll have a more of a tehnical aspect to it which is good because I can understand that to.
Both of you supplied quality information. Which believe me will be used.
Oh one other question to either 92 or big rush.
HOW DO I GET MY MUSIC OUT THERE
Ive heard from a couple of people that my music sounds good.
Not good as big rush though when I heard his music I was yeah this dude got some heat.
What is it like being commercial with your music is the people cut throat, fake what ever.
I can rap too nah fo real I can really rap.
So if one day you guy's might want to see what i'm about then I will send you a song and let know how I sound.
To ya'll thanks again for the quick replys both of you dudes are a god send.
When I installed 3, I completely uninstalled 2.5...but I left all of my refills on my slave hard drive for easy access. I left the refills on there when I made a backup of the software since I had to burn it just right. But it might just be that they were rearranged on the 3.0 refill and I may just be so used to the 2.5 that I haven't found them yet lol.
