M
Hey no apple'gies needed.Sorry, didn't see that.![]()
Actually ducking was a nice add!
Try compressing the OH track with a fast attack and release, side-chained from the snare track. It will duck the snare out of the OH leaving the snare close-mic to fill in the sound.
Yes, but that is why you choose a fast release to minimize that effect.
Cheers![]()
This is exactly what I did over the weekend and it helped a lot. Luckily Reaper makes that easy. Thanks for all of your suggestions.
I started to cut the snare out of the overheads with editing, but the problem is there are cymbal hits along with the snare quite a bit.
I'm not sure you can sufficiently hide the ducking effect with just the release control. I recall going through all sorts of trouble trying to mix unevenly played drums with a lot of bleed. Gates and compressors did weird things.
Is there a particular frequency range that's bothering you? Maybe you can take it down with one band of a multiband compressor, leaving much of the cymbals untouched.
you should post your luxurious results.
It seems like this thread struck a nerve with you, CMB. Are you okay?
