I was using it for the first time this evening with just a guitar plugged right into the input, is it normal to get a grainy buzzy sort of sound when doing this? Is this preamp more for mics?
I just tried it with a microphone it sounds fine just what i expected, great warmth.
It might be the cables, i was using balanced patch cables to plug in my guitar since i am loaning out my guitar cords. my signal is guitar into channel one of the preamp, preamp connect with an xlr into a M-audio pro-fire 2626.
What voicing did you have it on? This has some presets are are "suggested" to use on a given source. Be that percussion, voice, guitar, etc, as I'm sure you've noted just by looking at the main knob in the middle. Did you have it on a "warm" setting? That's ART's way of saying they're trying to emulate a real tube sound by adding certain noise artifacts/distrotion to the signal to color it to give it a similar sound a real tube pre amp might. Try the neutral settings if you haven't already (all of them, screw the suggestions). Also, check your gain settings and such. You could be overdriving the gain knob (and/or have the +20 db gain switch pushed in) and have the output knob too low, in order to get a reasonable level on your DAW. Read it's manual on "Getting the best noise performance out of the ART TPS II). They'll give you step by step on what to start adjusting first, in order to dial in your tone of choice. At least that's what they do in the manual for the ART PRO MPA II, which I own (and haven't had any issues with overdriven DI guitars, unless I purposefully overdrive it).
The IS a combo jack on the front saying mic/instrument, so that means it SHOULD be okay to DI a guitar into there. Usually, though, there is some sort of button on these things to tell it whether you're plugging in a mic to that jack or an instrument.
When all else fails, get in touch with Yorkville sound (they own ART) and ask a tech on the phone. They speak real English and ACTUALLY know a thing or two about the gear they manufacture!
Second Jive Dude: 'S'mofo butter layin' me to da' BONE! Jackin' me up... tight me!
Randy: I'm sorry, I don't understand.
First Jive Dude: Cutty say 'e can't HANG!
Jive Lady: Oh stewardess! I speak jive.
Randy: Oh, good.
Jive Lady: He said that he's in great pain and he wants to know if you can help him.
Randy: All right. Would you tell him to just relax and I'll be back as soon as I can with some medicine?
Jive Lady: [to the Second Jive Dude] Jus' hang loose, blood. She gonna catch ya up on da' rebound on da' med side.
Second Jive Dude: What it is, big mama? My mama no raise no dummies. I dug her rap!
Jive Lady: Cut me some slack, Jack! Chump don' want no help, chump don't GET da' help!
First Jive Dude: Say 'e can't hang, say seven up!
Jive Lady: Jive ass dude don't got no brains anyhow! Shiiiiit.
