Protools Autotune Help Please?
  • Thread starter Thread starter Shack
Shack
Hi, I have just purchased Autotune 4 and intend to do my pitch corrections using Audiosuite rather than real time so as to avoid system limitation problems. My problem is that the Autotune manual contains no information about using Audiosuite. Can anyone please explain to me how to go about using Audiosuite or tell me where I can find any help files I can read up please? Thanks.
By the way I run PT LE version 6.4, using Digi 001
Thanks. I can see it in the menu, I just did not know how to apply it in AS, but think I have it figured out now. I have been told by someone to select the portion I want to correct on the wave file and then open Autotune via AS and not as an insert, then I should be able to preview and then when happy with it, I can save, after that, I can then close AT. I have not tried it yet and hope it works that way.
yeah, that's how you do it. the button is called Process in the AutoTune window. this will render the plugin to the selected region :cool:
