tkingen
Djembes Rock
If you line up a bunch of different pres from different manufacturers that are based on the same chip (i.e. Burr Brown INA217 OR INA163) are they all going to sound pretty much the same?
Robert D said:Circuit topology is really the biggest factor, followed by components used, assuming reasonable quality components in all cases.
tkingen said:If you line up a bunch of different pres from different manufacturers that are based on the same chip (i.e. Burr Brown INA217 OR INA163) are they all going to sound pretty much the same?
dementedchord said:while the opamp can contribute to the sound and whether or not an instrumentation amp is used (if that's what chess is refering to)can also affect the sound... it is by far the least significant considerations overall... circuit topology dominates...
chessrock said:Same question I asked RobertD ; If an instrument amp is going to be used, would you agree that the topology is generally going to be somewhat limited, to an extent? Or are there a rich and varied number of possible topologies being used with something like an INA163 or 217, for example?
MCI2424 said:The reason so many cheap pre-amps using either of these chips sound so similar is that the designs use very few external components (cheap to make) and given that, there are only so many configurations that can be made to work (ie: the designs are minimal and similar).
A more expensive topology involving decent transformers etc. would add much more $$ to just the parts list alone let alone the design time, board layout, testing and all other things engineering that cost $$.
chessrock said:Or, more accurately ... could you at least see where one might raise that question or suspicion, without being totally out of line? Do you think it would be a valid concern, without even having listened to the unit or having direct experience with it? Hypothetically speaking, of course.
I'm gonna go out on a limb and assume you're talking about the DAV pres.chessrock said:So would it be safe then to assume that, if a given unit wasn't utilizing a "more expensive topology" ... didn't have a transformer anywhere in the path, and used essentially lower-grade caps and other supporting circuitry ... would it be difficult, then, to justify a significantly higher cost for said unit?
chessrock said:Great explanation.
chessrock said:But would you agree that the use of an instrument amp like the ones in question (i.e. Burr Brown INA, Analog Devices, etc.) will greatly influence the topology?
And would you honestly say that the topologies using an instrument amp at it's core tend to vary wildly from one unit to another? ... or would it be safer to say that they tend to be more similar in their layout than different?
