Bobbsy
Boring Old Git
Most of the knowledgeable sources disagree with you Bobbsy.
Everything you were Afraid to Ask about Cables
https://www.google.com/search?hl=en...=any&safe=images&tbs=&as_filetype=&as_rights=
bouldersoundguy, where did I say anything about unbalancing a signal?
Balanced is balanced. If that article (it's too "all over the place" for me to bother wading through every link) says that balanced with a TRS connector can only go 20-25 feet while balanced runs with XLRs at the end can go farther, then it's bunkum, not a "knowledgeable source". And, with cable of the suitable spec, even unbalanced signals aren't "degraded" until the length of the run is huge. It's electrical interference, not gradual degradation that is the risk on long runs.
I have a hundred metre (i.e over 300 foot) snake with 16 XLR connectors and 8 TRS ones (built that way for the particular application I had). Next time you're in Queensland, come and do some measurements. You won't find any extra noise or any difference in signal level between the XLR-terminated pairs and the TRS ones.
As an aside, in the last TV facility I designed, every audio circuit went via a central patch panel. Runs from that Master Control area to the far reaches of the building were approximately 85 metres--and the patch leads were quarter inch TRS (though "B gauge" rather than "A gauge). Circuits were checked regularly, usually with a Lindos audio test set, and even feeding 85 metres to the central hub, patching with a double ended TRS lead, then the 85 metres back did not result in a measurable degradation of the signal. I should also mention that there were at least three "Krone" blocks in the path, but that's another issue.
Connectors, unless there's something wrong with them, don't lead to signal degradation.
Finally, as bouldersoundguy said, count me as one who read your mention of adaptors as meaning you were bouncing between balanced and unbalanced--which, of course, means the whole circuit might as well be unbalanced.
Edited to Add: In fact, even your article agrees with me. In a section trying to sell you a certain brand of TRS-terminated cables, it says:
The TRS "Tip-ring-sleeve" cable (2-conductor plus ground) This is a cable for balanced signals just like the XLR above, it just has different connectors.
Note the "just like the XLR". Later on in the same section it says that these cables (again like XLR) can be used for long runs.
