crazydoc
Master Baiter
I'm trying to find a cheap (read "free") way to test the frequency response of mics. The purpose would be to compare a mic's response before and after modification, either against an unmodified version or against a reference such as the ECM8000. As such, it doesn't have to be correct in absolute values, but only reproducible for comparison purposes.
I've used the analysis tool in Cool Edit 96 demo version (this is the only recording/wav software I have) to compare several mics, using the noise of my computer fan as a source. Unfortunately it has quite a few peaks and valleys in it.
What I think I need is a white noise source. I've thought of using the air escaping from a tire valve, but can't figure out how to get the car into the house.
Any thoughts on a white noise source? I have a couple of circuits I could build if worse comes to worst.
I'll attach the graph I've done. Sorry about the resolution. The graphs would be a lot easier to compare with even a smooth noise source, not necessarily even white. Also, I tried to put too much in one picture - it all got bunched up at the high frequency end.
Again, any thoughts on a cheap source of noise? Thanks
