pikingrin
what is this?
This may not be the appropriate spot for this...if it needs to be moved then do what you must.
I'm getting a few pedal kits for christmas this year and I've been busy printing off the info for them. I'm fairly certain that one has a PNP transistor in it so I've been doing some digging around as to what could happen if I forget and plug my 1 spot into it (or a power supply when testing) that isn't the right polarity. Apparently, if it's in line with any NPN transistors, everything will short to ground and no pedals will work. No big deal, as long as I can remember which is which (will probably mark it just to be sure).
But, I have also read that I can change the way the power input jack is wired and I can daisy chain it with any "standard" NPN pedals. Is that true?
I've also seen that 1 spot makes a reverse polarity adapter (shown here) but it only specifies for use with keyboards, etc. Would that do the trick instead of wiring the power input backwards?
