qb2k5
(Warning: very detailed)
I tried to hold off from making this topic but I couldnt take it anymore. Im so frustrated Im thinking about just going into a studio to finish up on my album.
The problem is that has been frustrating me is that all my vocals no matter what song I do always sound muffled and not in front of the mix without EQ. Its like if I have a my hand infront of my mouth while recording.
I bought this setup because most people reccommended that the at4040 is a workhorse and is perfect for rap vocals. I know it can sound clean, but I think my preamp is the problem. ive been reading how alot of people use very little EQ when doing vocals. I have to use alot of EQ in the highs so people can hear what Im saying. I upgraded this from my old MX602a and MXL1006 mic.
(Settings)
My room acoustics had been well-padded with 3inch triangle foam.
My chain is At4040-bal monster cable- Dmp3-bal monster cable-Delta 44- Protools LE- Delta44 out to Wharfedale 8.2.
I have my DMP3 gain knob set to 3 o'clock with Low cut 75hz cut switch. And my At4040 has the -10pad on, and the Low-cut switch on.
Heres some clip examples.
Song titled- "Hey Miss" ( popping sound is coming from the website, since these are new uploads)
1. No EQ, No reverb, No comp. Just flat. (Notice lack of highs.)
http://www.jamwave.com/streamhi.aspx?CID=11324
2. EQ (3.9 gain+ in 2890,and 8.1+ gain in 6974), No Reverb, comp
http://www.jamwave.com/streamhi.aspx?CID=11325
3. EQ (same as above), reverb, and comp.
http://www.jamwave.com/streamhi.aspx?CID=11326
4. My final mix
http://www.jamwave.com/streamhi.aspx?CID=11328
If anyone can take the time and give me a good set of settings for Waves REQ (something I could use all the time), than that would be much appricieciated.
Thanks alot HR
(Settings)
4. My final mix
Thanks alot HR
