N
ninecows
Hi there
I hope this thread can turn into a tutorial for all newbies on mixing drums, but at least just help me getting my drums mixed.
I'm using jamstix 2 for my drums (yeah - start flaming if you like, but I don't have a drummer nor a drum kit so...)
My problem is that I'm a total newbie on mixing and having to mix a complete drum kit is just way too complex for me. You might as well ask me to climb Mount Everest tomorrow. I have absolutely no idea on where to start and how to get where I want to end. I've read several guides n tips about mixing, but I think I need a basic starting point, somewhat close to the sound I want before I can go anywhere at all. So this is my cry for help ;-)
I have rendered wave files with 8 bars of a very basic drum track with kick, snare, toms, hi hat, ride, cymbals and ambience on separate tracks. They're on the link below together with a reaper project file for your convenience if you're using reaper. The file is pretty large - some 50 MB. Hope that's ok.
http://www.ninecows.dk/mix-my-drums.zip
These samples are my starting point. Obviously my songs have different and more interesting drum tracks and other instruments as well, but I would like the sound of the drums to be consistent throughout my album and build the rest of the mix around the drums. Seems like a good idea, but will it work?
Anyway. The place I want to end is with a sound somewhat similar to the drums on "The final cut" by Pink Floyd... They seem very powerful, but yet open and clear to my ears.
So how do I get there? I'm guessing that the right EQ and compression will get me pretty close... and of course a bit of reverb. I'd like to use the plug-ins in Reaper because they're free, got all the typical knobs available and are universal (as they doesn't try to model some old analog hardware), but other free plug-ins would do as well.
And as I said: I know that the rest of the instrumentation will affect how well the drums sit in the mix and that there's no "golden recipe" on mixing drums. I just hope that if I/you carve out reasonable bands with the EQ on the drums, then I should be able to fit in the rest of the instruments (guitar, bas, piano, hammond organ, vocal and a few synths) as well.
I hope someone in here will be kind enough to get me started. I don't expect magic, but a reaper file in return with ReaEQ, ReaComp and reverb with decent settings for my goal would be fantastic
Otherwise, specific advices like "cut 6 db at 350 Hz with a q-setting of 1" or "set the comp ratio to 1:2, attack to 2 ms" etc... are also fine. I'll keep posting the results here (with smaller files of the samples) so other people can learn from this as well.
Thanks in advance and a nice day to all of you
