TragikRemix
I am NOT a Gear Whore. ;)
Ok, so here is my first real attempt at mixing drums.
Please don't discriminate based on my playing abilities, im not a great drummer, i play guitar
But i do know i hit them "right". also, advise that the ride cymbal is actually an 18" crash cymbal, i sold my ride and hadn't purchased my new one yet, at this time.
I dont even know if it is considered mixing, the way it came out. I really don't know if it is good or not. I want your criticism and maybe some info to help me, (plus an explanation if you could). First off, there are two files; one is the regular mix, and the other is the regular mix, with Drumagog (Demo) samples replacing the Kick and Snare.
I don't know much about the plugins i used, but i found some info online about how to (roundabout) EQ each mic, and i went with the Digi Presets on the Compressors and Expander/Gate, with (i cant remember if at all) MINOR adjustments, but i really don't know what i am doing with them. All of the compressor settings are the same too. The EQ varies slightly.
Using Pro Tools 7.0, Digirack Plugins, Digi 002r and Behringer ADA8000 (lightpipe)
Heres exactly what i did:
Track 1: Kick (AKG D112)
-4 Band Digi EQ
-Output=2.9db
-LF=100hz, +2.0dB
-LMF=406.7hz, -2.0dB
-MF=1000hz, 0dB
-HMF=2.5khz, +2.0dB
-HF=6khz, 0dB
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
-Digi Expander-Gate (set to "Kick Gate with Key Filt"
-Threshold=-15.3dB
-Ratio=40.0:1
-Attack=.30ms
-Hold=88ms
-Decay=360ms
-Range=-77dB
Track 2: Kick (Shure SM57)
-Flat EQ
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
-Threshold=-15.3dB
-Ratio=40.0:1
-Attack=.30ms
-Hold=88ms
-Decay=360ms
-Range=-77dB
Track 3: Snare (Shure SM57)
-4 Band Digi EQ
-Output=2.3db
-LF=100hz, +2.0dB
-LMF=399.1hz, -3.1dB
-MF=1000hz, 0dB
-HMF=2khz, 0dB
-HF=6.53khz, +2.0dB
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
-Digi Expander-Gate (set to "Snare Gate with Key Filt"
-Threshold=-26.1dB
-Ratio=30.0:1
-Attack=.00ms
-Hold=200ms
-Decay=130ms
-Range=-80dB
Tracks 4 and 5: Overheads (AKG C430 Pair) (Exact Same)
-4 Band Digi EQ
-Output=0db
-LF=100hz, +2.0dB
-LMF=374.3hz, -2.0dB
-MF=1000hz, 0dB
-HMF=2.5khz, +2.0dB
-HF=6khz, +2.0dB
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
Master Output
-D-Verb (Reverb)
-Input=-1db
-Mix=30%
-Diffusion=80%
-Decay=347ms
-Pre-Delay=0ms
-HF Cut=11.93khz
-LP Filter=Off
Drum Bounce Pre-Drumagog
Drum Bounce With Drumagog Samples
Hopefully, the conversion to mp3 didn't COMPLETELY destroy it...
-4 Band Digi EQ
-Output=2.9db
-LF=100hz, +2.0dB
-MF=1000hz, 0dB
-HMF=2.5khz, +2.0dB
-HF=6khz, 0dB
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
-Threshold=-15.3dB
-Ratio=40.0:1
-Attack=.30ms
-Hold=88ms
-Decay=360ms
-Range=-77dB
-Flat EQ
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
-Threshold=-15.3dB
-Ratio=40.0:1
-Attack=.30ms
-Hold=88ms
-Decay=360ms
-Range=-77dB
-4 Band Digi EQ
-Output=2.3db
-LF=100hz, +2.0dB
-MF=1000hz, 0dB
-HMF=2khz, 0dB
-HF=6.53khz, +2.0dB
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
-Threshold=-26.1dB
-Ratio=30.0:1
-Attack=.00ms
-Hold=200ms
-Decay=130ms
-Range=-80dB
-4 Band Digi EQ
-Output=0db
-LF=100hz, +2.0dB
-MF=1000hz, 0dB
-HMF=2.5khz, +2.0dB
-HF=6khz, +2.0dB
-Digi Compressor
-Gain=0dbB
-Threshold=-31dB
-Ratio=4.00:1
-Attack=11ms
-Release=50ms
-Knee=80
Master Output
-D-Verb (Reverb)
-Input=-1db
-Mix=30%
-Diffusion=80%
-Decay=347ms
-Pre-Delay=0ms
-HF Cut=11.93khz
-LP Filter=Off
