F
Fusioninspace
I just put some GFS P-90s in my Hamer XT Goldtop to replace the stock Hamer ones. It really nailed the sound I was looking for... Based on everyone's suggestions from my previous post, I leaned toward the Duncan Phatt Cats (P90s) cause that's what I put in my Hamer Echotone. The Phatt Cats are designed to replace Humbuckers - and that worked/sounded perfect on the Echotone. But when I went to try to find Duncans that had the same specs in a soap bar, there was nothing that matched.
So I go to GFS and they have some that are close to the spec of the Phat Cats - I end up going with the GFS because their specs are close to the Duncan. The other day I get an email back from Hamer responding to an email I sent them requesting the impedance on the stock Hamer P90s.
Keep in mind that I thought the stock Hamer P90s sucked. The Duncan and GFS both have the exact sound I was looking for. Here's a run down on the DC resistance each pickup:
--------Hamer--GFS---Duncan
Neck____8.4____8.0____7.98
Bridge___8.8____8.8____8.49
Looking at these numbers, there is really no significant diff (at p=.05) between any of these
. Why does the Hamer suck and the GFS/Duncan excel? I'm guessing magnets and maybe the wire size.
Is the rule that you really don't know what they're going to sound like until you install them?
. Why does the Hamer suck and the GFS/Duncan excel? I'm guessing magnets and maybe the wire size.Is the rule that you really don't know what they're going to sound like until you install them?
