sile2001 said:
Actually phase reverse is a valid name for it. Polarity refers to electrical charge, phase refers to the sonic characteristics of a waveform. Reversing the polarity of an electrical signal causes the phase of the waveform that signal represents to be reversed.
So it's still phase reverse
Nope, phase reverse is an absolutely horse shit name for it, because it does NOTHING to the phase relationships of the signal.
Phase is an issue of time, polarity is an issue of electrical charge. You can not fix an issue with one by using the other. There is no way to "reverse" phase. Phase is TIME based, and unless you have a flux capacitor, and a really good imagination, you can not reverse time. They are completely separate phenomena, and while they can affect one another, they do not do the same thing. Inverting phase does not, and can not, change the time relationships between two signals.
The problem is, when people learn about this stuff, it is always shown using sine waves, which make it very simple. And with a sine wave, 180 degrees out of phase looks an awful lot like reversed polarity. Unfortunately, there is not a naturally occurring sound in the world (nor most synthesized sounds) which acts like a sine wave. They change over time. Add to this the fact that no phase issue are 180 degrees out of phase at any important frequency, and never 180 degrees out at all frequencies (think about it, it is physically impossible).
The fact is that, while the polarity switch may fix an issue at one frequency, it will ALWAYS double the problem at another frequency within the harmonics for the same pitch. The major problem with calling the polarity switch a "phase" switch is that it leads to a major misconception amongst many engineers (both experienced and inexperienced) that it will "fix" phase issues. It will change the relationships, but it will not eliminate the problem. Try it both ways, and see which sounds better, but if you still have a problem, you may have to do some playing with where in time the parts if the track exist, as that is where phase issues come from. I only hope you tracked those multiple mics to separate tracks if you do.
Light
"Cowards can never be moral."
M.K. Gandhi
