Patrick108
Member
I recently worked with another musician in my home studio. When we ready to use my condenser mic which required phantom power, I switched the phantom button on my Focusrite PC Interface which had eight inputs. The switch was designed to activate phantom power for inputs 1 through 4. I connected the mic cable to input 1. Before I ever worked with her, I was of the opinion that once input 1 through 4 were activated for phantom power, I should not connect the cable for guitar or keyboard or drum machine (or any other instrument not requiring phantom power) to the other inputs 2 through 4. She disagreed with me and said that it did not matter, and that if I used the other available inputs no damage would result, either to the interface, my laptop, the DAW or the musical instrument itself. Is that true? Normally I would use inputs 5 through 8 for other instruments not requiring phantom once inputs 1 through 4 had been switched on for phantom. So I need guidance on that. Can I get away with using inputs 2 through 4 for instruments not requiring phantom power? Thanks
Patrick
Patrick
