tourettes5139
Hey all,
I've been lookin' at these pedalboard snakes at www.pedalsnake.com and I was thinking I'd try my hand at putting one together myself, for the fun of it. I want to have a power line (for a oneSpot adapter for the pedals), lines for the fx loop, a dual footswitch (channel switching and reverb for a Carvin Legacy), and the output from the pedals going into the front end of the amp.
I need to know what cables I should use to actually make the snake. At the above link, it looks like they're using midi connectors, although the actual wiring may be something different.
A few questions.
1. Would I be able to use a DB25, CAT5 or something like that (for the fx loop, footswitch, and amp input)?
2. What would I use for the power line?
3. Assuming I use DB25 or something, I could use a common ground for the audio signals, right? Or would I want to isolate them? I'm assuming I would have to isolate the ground for the footswitch signals for it to work correctly. I don't want ground loops or anything like that (obviously).
I'm assuming it would be best to not have the power and the audio running on the same cable/connector, so I would probably run two cables, one for the audio, the other for power, and then heat shrink around them, or something similar to keep everything neat.
If I use DB25, I could just have a breakout box/cable on the board, and one at the amp, and then just hook up the cable inbetween for a nice, easy setup. If I'm thinking about this whole thing correctly.
Any ideas, input, advice, $0.02, etc.?
Thanks a ton!!
JM
P.S. another link, the patent for his design. PedalSnake Patent
A few questions.
Thanks a ton!!
JM
