C
Captain Whisky
Good lord, what have I done?
haha
haha
hahaso how does it sound panned apart from each other?
it does look like between 45-90 degrees most likely a sideways pointing mic about 2 feet from the other mic
if it works it works.
I'm talking about guys in a spare bedroom miking their shit. Where would one have to really worry about it?
Tracking acoustic guitar and vocals at the same time would be one case, or two acoustic instruments or two vocals etc.
If you're using mics with sensitivities very close to the same with exactly the same preamp gain AND you can set the faders at exactly the same levels without adjustment and get a decent mix, it might help.Tracking acoustic guitar and vocals at the same time would be one case, or two acoustic instruments or two vocals etc.
Huh? What is the point you (or Greg) are trying to make here? Presumably that the numbers, or ratio' are no good or won't apply because or unless these 'conditions exist? Maybe I'm misunderstanding. The only thing of use to get out of any of this is to understand the underlying principals, knowing why unwanted cross bleed is doing what it does, and knowing what you can do about it; Get your -9db or what ever if you don't have to have to hear it..If you're using mics with sensitivities very close to the same with exactly the same preamp gain AND you can set the faders at exactly the same levels without adjustment and get a decent mix, it might help.
Otherwise, what Greg said.
Huh? What is the point you (or Greg) are trying to make here?..
And it's interesting that we're in agreement then in that it doesn't matter how you get there. But it is the underlying principle is where the value of it is. It seems odd to me so much made over what it's called, maybe it's the 'rule part of it? Ok. It's flexible. There's variables.My only point is that these archaic recording rules and regulations are stupid, and worrying about them is even stupider because the "rule" can be broken over and over with awesome results. I personally don't care if anyone whips out a tape measure to set up mics. I just know that it isn't necessary.
These rules of thumb were established when bands were recorded in the same room with similar mics.
Be careful there. We're talking about the interaction of one source in two mics. So as long as that one source is 9bd quiter in one of the mics (and presumably the other source is 9db quieter in the other mic)...As long as one Mic signal is at least 9db quieter than the other one, you will not have phase problems. How you make that happen is up to you.
lacing stage monitors to avoid creating a phasey mess around the performer's head.Ding!..The concept of the 9db difference is much more important to understand than the 3 to 1 rule, because the rule is just one way to make that happen (under the right circumstances)
