D
Danny Hays
Hello. I just joined this forum and I'm not sure where to post this. I worked at Universal Studios FL for 20 years. I have an old Otari MX5050 MKIII-4 that was a prop from an old venue, Murder she wrote, when they changed it to Herc and Zena, now it's Transformers. I want to sell it on Ebay along with the roll around stand, Auto locator with roll around stand, but it has a problem I need to fix first. During playback, when it gets into the middle of the tape, it starts having an inconsistent playback speed problem, as if the pinch roller is worn or capstan is worn. Like tape slip. The capstan is worn smooth where it touches the tape but if I remove the tape and hold the tensioners in and press play, I can barley stop the pinch wheel from spinning. Maybe the supply reel that spins the other direction to keep the tape tension right, is pulling back too hard, causing the tape to slip. The machine needs a good cleaning and calibration. Is there any internal adjustments I could make to fix this? Any advise would be appreciated.
If this isn't the right place to post this question, is there a better place to post it? Thanks for any help I can get. Danny
