Omitting certain frequencies from mic and amp
  • Thread starter Thread starter pure.fusion
So, there's no frequency mod I cannot do *after* I've recorded a track?
I don't need to prevent certain frequencies from hitting the disk? It's always an option to change it afterwards?
FM
99.9% of the time, yes.
The one exception is that sometimes a frequency mod, to use your term, changes the way an amp breaks up, and you WANT to capture that effect. For example, a wah pedal is basically a foot-controlled filter control that really juices a narrow band and somewhat attenuates the rest. In front of a just-breaking-up tube amp, that can allow you to radically change the way the amp breaks up - listen to something like the solo Jimi takes on "Burning of the Midnight Lamp," where he's taking a gritty breakup and, when the wah is down to really juice the treble frequencies, pushing it in and out of saturation. It's a cool effect. Also, in the modern metal world a lot of guys put a Tube Screamer in front of a high gain head not for added gain but because it effectively acts as a pre-EQ, rolling off a bit of low and high end energy, and really helps juice the midrange frequencies (especially if you're boosting the volume as well).
But, when in doubt, yeah, unless you're after a specific tonal effect you're way better off just doing EQ tweaks in the mix so you don't have to get them right before you know what "right" is.
FM
Yes, yes, and yes. The only thing different about EQing a track on the way in is that you cannot undo it. That's a bad thing.
EDIT (to DrewPeterson7) You're right, of course, but I'm pretty sure he's talking about EQing the miced signal, not EQing the guitar signal into the amp.
Yessir. That's my query, and it's certainly been cleaned up.
I'll make up some more stupid questions soon :p
FM
