O
omtayslick
Does anyone have any info on mods for this mic? Anyone done it? If so, what do you think?
demto said:I have trolled through the net and cant seem to locate all articles on MK319
mods, but here is what I have managed to find.
1. Remove the HF boost discs.
2 Stick felt to the diaphram side of the plastic seperator which seperates
the diaphram area and the electronics area.
3 Change the existing 510meg resitors to 1gb resistors.
4 Upgrade the diaphram coupling cap to silver mica or polystyrene.
5 There are 3 x 1uf electolyctic caps in the electronics circuit board.
apparently one of these needs to be changed for a better type. I am
going to change all three fo 1uf 63v polyester.
6 To be honest I am going to change as many of the remainining components
as I can for better where possible. I believe it cant do any harm even if
it doesnt do any extra good.
The order of importance seems to be 1,5,3,4,2
As yet I havnt done any of these mods as I am still obtaining the parts
I will need. When I have done this I will give it a go. Lets hope for the best.
I also have a question on this mike.
The parts list in the manual calls for 2 X 68pf caps but 680pf caps are
fitted. The caps are marked 680pf and I have checked them by
measurement. Can anybody confirm whether this is an error in the manual
or error in the parts fitted at the factory.
1000pF polystyrenes from Mouser. There, you heard otherwise...demto said:I'm going to keep the caps at 680pf unless I definately hear otherwise.
Flatpicker said:You just take a screw driver, remove the screws holding the disk, take it off and put the screws back. Hard part is not letting the screwdriver slip and poke a hole in the diaphragm. Do that and the mic becomes a paperweight.
Flatpicker said:Oktava MK319 Schmatic
The 1gigs (R1 and R2) can be 10% and you won't hear the difference - get the cheapest ones you can find.
R7 and R8 should probably be the same. Are you measuring them with one side lifted up out of the circuit? They won't measure correctly unless you take at least one side out.
5% is fine. The only time you need to worry about resistor noise is when using carbon comps in high voltage circuits. In low voltage circuits like this, resistor noise is not an issue.demto said:I can get 'stock' 1gig resistors no problem. The 'stock' ones are 5%. I think they are reasonably low noise as well. I just wondered whether they needed to be 'ultra low noise' or any other special needs??....
What is the value of R7?demto said:Anyway, as the manual calls for 1.8K I am inclined to fit a 1.8K...
