M
mario_c
I've done a search and cannot seem to find a post or reply which answers my question. I am wondering how I can go about using a program such as Room EQ Wizard to find the difference in EQ between two microphones and export the eq data file to be imported into a plugin within a DAW such as Cubase 8. Is it possible to calibrate REW with one mic (such as an AKG c414b-uls) instead of calibrating with the measurement mic (flat frequency response mic, such as the ecm8000) and then run a measurement of a second mic (like a c414 xls) to determine what the difference in frequency response is? Can I export the eq data to import into a plugin in Cubase?
I have used q-capture and q-clone to obtain the frequency response of my preamps to see how they are impacting my sound. I am able to use those frequency responses to Ed a track now if I want which is nice (of course it does not allow me measure the harmonic distortion of the preamp or to accurately measure the difference of a mic).
I use PC so I cannot use Fuzzmeasure.
To summarize:
1) How can I obtain EQ data that reflects the difference between my microphones which can be used as an EQ setting?
2) How do I export it? Which plugin can I import it with?
3) Is there any other data which may be useful (that can be found in REW or the likes) when comparing two mics such as octave distortions that I can also import into a plugin?
To summarize:
