M
mixsit
Re: Ok then, BB
I would say that's definiely the case. As playing techniques get smoother, more consistent, stray spikes become less. But limiting is still part of the sound and levels we're often going for.
This can be tackled at the track level, and plugs can work well in the mix stage. UltraFunk's comp/limiter is a good one for example. (Part of sonar now). It's very quick and look-ahead also helps.
The RNC is very fast (it's not brick-wall), but I don't know if it's THAT fast. Especially in super-nice. Doesn't the attack get slowed down also in super-nice? Never really checked that out exactly.
Wayne
Speedy VonTrapp said:snipp ...On some tracks, I'm getting some of those peaks that I don't want. Perhaps the drummer hits a bit harder on a couple hits, etc., whatever. (Is that even what might cause something like that?
I'm limiter-less. What are my best options? Can the RNC help this situation out if my budget says that no matter what, I've got to work with what I've got?
Or are there limiter plug ins that are worth downloading? Or if the budget says it's ok, but limited, (as most home recc'rs), what should I grab for limiting? Is there an external hardware unit you'd recommend, or is there something software side that you'd recommend?
OR... is it something thath is helped in a different manner altogether, like mic placement, or smacking the drummer, etc?
-Speedy
Wayne
