Hello. Im new here but it isnt most important. I have a question referring to noise.
I have a high quality audio interface connected to the ins of the Behringer FBQ 1502
equalizer (Line Out ---> EQ Inputs). Outputs from the EQ are connected to Behringer
MDX 1600 Compressor using CHINCH cables with CHINCH // JACK 6.3 mm adapters.
Output from MDX 1600 is connected to the MIXER which I use to switch between
HEADPHONES and SPEAKERS listening.
I noticed some noise when listening through HEADPHONES. I checked it with
no FBQ and MDX in the signal path and I have got a completely noise-free
signal. It is not a hum but it sounds more like a quiet sine wave and other
noise with it. Could You have any idea how to remove that noise from the signal ?
I cant work comfortably when I hear it.
Maybe the cables or adapters are making it ?
I thought about changing the cables, but Im not sure about the result...
cheers,
Styropain
cheers,
Styropain
