I
Ibiza
Hey, I'm new to the forum, not to mention new to recording.
I have a simple Question.
My band will begin recording within the next week or so. we are using SM57's for the amps and the Drums(octava overheads, Beta 52 for kick). For the vocals we will be using a sennheiser or if needed an SM58.
We are using 2 powered mixers to mix the mics. Then we are planning to run this to my guitarists beast comp system where we will be using N-track.
I am planning on running the mics through the mixers, then using the mixers main output and connect both to a adapter which will turn them both into a single 1/4 male.
First of all, do any of you see any problems with what i have told you?
And second, What type of cables should i use to go from the mixer to the adapter which will go into the comp.? (I.e. speaker cables, bantam cables, insert cables, patch cables etc...)
Thanks in Advance for all your help, and ill be sure to post when the recordings are done.
Thanks again, Cesar
Thanks again, Cesar
