williambslack
I've followed the 388 enthusiasts on here for a while (bought a 388 years ago not knowing what it was). Usually you 388 fans answer questions without me having to ask, but now i've got a specific one:
When i turn on the 388 (which has worked great for a long time), about half the time the right channel won't play back, and it's not due to a heaphone/speaker connection issue. When it's acting like this, the right-panned even channels WILL still record, just no playback.
when the right channel is out, i can switch the unit to MONO, and I get signal in both speakers, so again, it must have something to do with the repro head, no?
here's a weird thing: when it's acting up, i found that a loud source panned to the right (a mic input, or simply panning all recorded tracks right and cranking them up) will eventually "wake up" the right playback, almost as if that side needs to be warmed up. after that, the right side more or less functions until the 388 is turned off, though sometimes at a lower level than it should.
What could this be due to? fuses? am i hurting the unit further with my "warm up" method. any ideas would be appreciated.
