G
gb59
hello everyone,
I'm putting together my home studio in a new construction that will be underway within a couple of weeks. I'm now in the process of aquiring the equipment I need/want. Below I've listed my wish list. I'm looking for possible direction from the members of this forum.... Am I heading in the right direction or is this list just not right.
-24~32 channel analog board ( soundtracs/amr/soundcraft/hill audio..) (budget = $2,000.00)
-motu 24i/0 (budget = $1,000.00)
-motu 2408 mrkII (already have)
-pentium pc (already have)
-cubase (already have)
-other toys (up to $4,000)
anyway this will be the overall system. I planning on acquiring some mic pre's, compressors, mics and other goodies along the way. )As you can see I will most likely end up with a bunch of previously used gear but that's ok.)
As for recording, I'm thinking I will use the mic pre's from the analog mixer and record on to the pc throught the motu interface. For mixing I was thinking of sending the tracks back through the board again and using the eq's of the analog board as opposed to using the pc's eq's. Most likely the board I end up with will not have any automation on it so I will have to mix levels with the pc through Cubase. As for fx, I was planning on using some outboard gear as well as the effects that I have available through Cubase.
Does this make any sense? I'm looking to record a variety of styles of music and want to be as versitile as possible with my studio. And of course I'm wanting the best sound that I can get.
Any suggestions re: boards, pre's, pc.... are much appreciated. Since I'm still in the beginning stage, I'd like to get as good a system that I can for about $7500. (my budget)
